Was hat es damit auf sich?
Ich finde nur etwas mit Canada und 50ccm?
Elite 14 WRR 50
Basic Technical Data
Engine
Two stroke Liquid Cooled, 5 port
Number Of Cylinders 1
Size, Capacity 49,9 ccm
Power Output 18 HP at 13 500 rpm
Torque 8 Nm at 12 000 rpm
Carburator PHVB 19 Dellorto
Fuel Admision Carbon Fiber Reed Valve Direct To Crankcase
Ignition Electronic
Starting Hand Pull Type, Manual
Clutch Centrifugal, Friction Automatic
Frame
Welded Of High - Strenght Steel Tubes
Lining Three Parted
Brakes
Front Wheel Mechanical Disc Brake
Rear Wheel Mechanical Disc Brake
Wheels
Front LIGHT ALLOY 6,5" - 63
Rear LIGHT ALLOY 6,5" - 63
Tires
Front 90/65 - 6,5" PMT - T40
Rear 110/50 - 6,5" PMT - T40
or 90/65 - 6,5"
Fuel
Gasoline Mixture Mixture of Gasoline 92 Octane or Higher + 2T Synthetic Oil
Mixing Ratio (After Break In Period)
50: 1
Tank Capacity 1 Liter
Speed
With The
Instaled Ratio up to 50mph(80km/h)
Basic Dimensions
Weight (48lbs.) 22 Kg
Carrying Capacity (240lbs) 110 Kg
Length 945 Mm
Width 470mm
Height 565 Mm
Colors Red, Black, White, Yellow
Pricing will be around $3900.00
Still less expensive that many other Euro brands.
To celebrate the announcement of this release Oz Minimoto is giving away FREE, any Cag aircooled bike with a purchase of any genuine Blata bike in stock for the month of October 2006.
Normal delivery charges still apply.
Also a genuine 50cc top end kit will be avaliable in early 2007 for anyone interested in upgradeing their genuine Blata 40cc bike.
Elite 14 WRR 50
Engine
Ignition Electronic
Frame
Lining Three Parted
Brakes
Wheels
Tires
or 90/65 - 6,5"
Fuel
50: 1
Speed
With The
Basic Dimensions
Length 945 Mm
Width 470mm
Height 565 Mm
